Setting the Fuel Pressure Regulator
Old May 7, 2003 | 01:16 PM
Marcum_Marley's Avatar
Marcum_Marley
Default Setting the Fuel Pressure Regulator
I was just wondering what everyone thought was the optimum fuel pressure regulator setting. I have an 86 with basically stock engine. I might be running her a little lean. Whats your thoughts? :flag
Old May 7, 2003 | 01:33 PM
STL94LT1's Avatar
STL94LT1
Default Re: Setting the Fuel Pressure Regulator (Marcum_Marley)
TPIS recommends 49/52 psi for the 86.
Old May 7, 2003 | 01:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Start with the vacuum line off pressure the same as with the stock FRP.
From there you need a way to monitor performance to find the sweet spot in FP:, i.e. a scan tool, a trap speeds or a dyno.
BTW, with my mods I'm running 48psi and dyno pulls show the A/F ratio at WOT is right on.
Old May 7, 2003 | 01:48 PM
ZylaRace's Avatar
ZylaRace
Default Re: Setting the Fuel Pressure Regulator (65Z01)
AFPR is a tuning tool.
Give the engine what it wants. i.e. Need scan tool data, trap speed,....
W/o it, you are shooting into the dark. i.e. Might as well keep the stock reg in there.
To Setting the Fuel Pressure Regulator
