93 slave cylinder
Old May 9, 2003 | 01:16 AM
blue30's Avatar
blue30
Default 93 slave cylinder
Hey guys where is the slave cylinder can't find it and is near the master cylinder. Which part should i replace first the master or slave don't know which one is giving me a problem :crazy: :confused:
Old May 9, 2003 | 08:07 AM
Aaron71771's Avatar
Aaron71771
Default Re: 93 slave cylinder (blue30)
Clutch slave cylinder? Are you having trouble shifting?
Its located on the bell housing on the drivers side, just in front of the transmission. You may as well replace them both since you are about to go thru clutch bleeding hell.
