I just got a 1985 Corvette last week, fixing minor problems with it.
I'm having a problem with the blower motor. It only works on the HI
setting.....it doesn't blow at all if I set it to a lower setting. I checked the
fuses in the fuse box but they all look fine. Is there a fuse under the hood some where that could be blown? Can anybody tell me what could be causing
these symptoms? Thanks! :confused:
Had the same problem....I took the relay off the front of the blower, and cleaned the contacts in the relay....Bingo! blower worked on all speeds!!! easy to do :steering: :steering:
