TPS Output voltage high
Old May 9, 2003 | 10:30 PM
Jeffmete's Avatar
Jeffmete
Default TPS Output voltage high
Because my '90 vette has developed a little surge in first gear I decided to go through the idle tech tip that includes setting the voltage on the TPS. I could onlyget the tps to go down to 0.63 volts, not the required 0.54. Is my TPS shot, or is there a range (by the way, it didn't fix the surge either).
Old May 9, 2003 | 10:33 PM
Corvette0096's Avatar
Corvette0096
Default Re: TPS Output voltage high (jhughes2101)
I would say there is something wrong with your TPS. :yesnod:
Old May 9, 2003 | 11:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your TPS is fine, just set the min idle and your ECM will take care of the TPS settings.
The early L98 had an adjustable TPS with slotted bolt holes; your TPS has round bolt holes and is not adjustable.
Old May 9, 2003 | 11:40 PM
Corvette0096
Default Re: TPS Output voltage high (65Z01)
:bb
:bb Mine is adjustable. always thinking all vettes are the same...But if you have that plug covering your idle screw adjustment dont remove the plug. The problem will be else where.
Old May 9, 2003 | 11:58 PM
Jeffmete's Avatar
Jeffmete
Thanks, I'll quit worrying about it. The problem I'm having is, mainly in first gear, the acceleration is not linear with throttle position. Idon't notice it in any other gear. Any ideas?
Old May 10, 2003 | 12:47 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I have my 89 set at .65 and it runs great.
To TPS Output voltage high
