transverse leaf spring
Old May 9, 2003 | 11:22 PM
Jerry D's Avatar
Jerry D
Default transverse leaf spring for 1986
Has anyone installed coils-over shocks instead of the transverse leaf
spring in the front? How are they working in comparison? Where they cheaper than replacing a new leaf spring and where did you get them?
[Modified by Jerry D, 4:26 AM 5/10/2003]
Old May 9, 2003 | 11:26 PM
vader86's Avatar
vader86
Default Re: transverse leaf spring (Jerry D)
Doug Rippie makes a conversion setup, I believe 'zelement' has them on one of his cars. The handling is reported to be a fair bit better.
Old May 9, 2003 | 11:28 PM
Jerry D's Avatar
Jerry D
Default Re: transverse leaf spring (vader86)
Who is Doug Rippie? Zelement is a forum person?
Old May 10, 2003 | 12:15 AM
Jerry D's Avatar
Jerry D
I found the Doug Rippie site but the cost of the coils are too high for me.
Old May 10, 2003 | 02:19 AM
don hall's Avatar
don hall
Default Re: transverse leaf spring for 1986 (Jerry D)
Citing the latest (July) issue of Corvette Fever-"10 Tips To Better Handling", page 64: "Get rid of the transverse leaf springs and mount up coilover shocks. Bilstein makes coilover shocks that bolt right into the stock shock mounts. With the high cost of replacement transverse leaf springs, this may not be as expensive a swap, and you can reduce the weight of the suspension by completely removing the leaf springs. Special bonus! With the coilovers, you can adjust the ride height of your Corvette for different tire and wheel packages in a matter of minutes. Try that with your leaf springs!".
Does this rationale make sense to you suspension gurus?
[Modified by Oldman, 11:23 PM 5/9/2003]
Old May 10, 2003 | 11:41 AM
don hall's Avatar
don hall
Default Re: transverse leaf spring for 1986 (Oldman)
Jerry D, I guess there is no interest or info......
To transverse leaf spring
