RR questions?
Old May 9, 2003 | 11:29 PM
rsafier's Avatar
rsafier
Default RR questions?
I have seen the ads for 1.6 RRs that are suppose to add 15+ HP just bolt on. So my question is exactly what would I need for my 85, is there anything else I would need to replace while changing the rockers and how hard is the whole process itself. I'm can handle small stuff, but never really have touched any internals before. Seems like a pretty cost effective upgrade if I can handle it myself.
Old May 9, 2003 | 11:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: RR questions? (rsafier)
Since your rocker studs are pressed in use self-aligning RRs; Comp Cams now has ProMagnums in self-aligning style to fit the stock 3/8" studs.
You should also install new seals and springs with a little more seat pressure.
