LINE-LOK KIT
Old May 10, 2003 | 09:49 PM
ASCOTTH's Avatar
ASCOTTH
Default LINE-LOK KIT
ANYONE KNOW WHERE I CAN ORDER A LINE-LOC KIT FOR MY 96?-------THANX FOR ANY HELP..................SCOTT :seeya
Old May 10, 2003 | 09:51 PM
hngacurv's Avatar
hngacurv
Default Re: LINE-LOK KIT (ASCOTTH)
Jegs and Summit both have Hurst roll control.
Old May 10, 2003 | 10:27 PM
ASCOTTH's Avatar
ASCOTTH
Default Re: LINE-LOK KIT (hngacurv)
THAT WAS QUICK---THANX FOR YOUR HELP-------SCOTT :seeya
Old May 10, 2003 | 10:28 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
pretty simple job, but can be time consuming depending on your skill with a double flaring tool.
Old May 11, 2003 | 12:44 AM
silver & red CE's Avatar
silver & red CE
Default Re: LINE-LOK KIT (Mr Mojo)
Does anyoe make an install kit that has all the fittings/tubing so no flaring skills are required?
Eric
Old May 11, 2003 | 10:10 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: LINE-LOK KIT (silver & red CE)
Eric
Not that I know of.
Old May 11, 2003 | 12:54 PM
silver & red CE
What's a good flairing tool?
Old May 11, 2003 | 03:32 PM
ASCOTTH's Avatar
ASCOTTH
I use a "RIGID" one piece, cost about $75 but the cheaper 2 piece jobs work just as well--the one piece is easier to handle though.---------- :seeya
Old May 12, 2003 | 12:11 AM
MrCrowley's Avatar
MrCrowley
http://www.zr1specialist.com/HAT%20W...ine%20lock.htm
Go to this website! You can get the hole kit from there. Then all you have to do is install it, easy as that! cya
Old May 12, 2003 | 07:49 AM
AlHale's Avatar
AlHale
Default Re: LINE-LOK KIT (MrCrowley)
I used this kit and it does make it so easy. With the Metric to ASE adapting BS, it is a pain. The kit makes the installation quick and the line quality is great. I recommend it.
To LINE-LOK KIT
