Rough idle
Old May 11, 2003 | 02:53 PM
oliver's Avatar
oliver
Default Rough idle
I have a 94 LT1 corvette with a rough idle. The dealer have change the wires plugs, coils, and distributor. They also told me the injectors all flowed correctly. The car runs great besides the idle. When cold it doesn't shake until the fast idle kicks down. The dealer told me the rought idle is normal. Any help would be appreciated.
Old May 11, 2003 | 02:58 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Rough idle (oliver)
Welcome to the forum :flag
The idle is a common area that tends to be very aggravating. It should be smooth since it is controled by the computer, but there are many variables that effect it.
Your best bet would be to do a search in C4 tech current and archives and you will have find alot of info.
Most questions have been asked multiple times and a search can give answers quicker.
Old May 13, 2003 | 04:36 AM
oliver's Avatar
oliver
Thanks for the help, can I just turn up the idle stop screw with out messing things up?
Old May 13, 2003 | 10:59 AM
JCAIRE2's Avatar
JCAIRE2
No there is a step by step process for resetting idle. See the menu bar at the top of the page? Click on tols/tech tips, I believe the process is listed there. :cheers:
To Rough idle
