Coolant pump install?
Old May 11, 2003 | 03:53 PM
Strick's Avatar
Strick
Default Coolant pump install?
Is it required to put thread sealer on the coolant pump bolts? The GM manual doesn't mention anything about it. How about the gasket, do you leave it dry or do you use something like Permatex? :cheers:
:flag :flag :flag
Old May 11, 2003 | 07:29 PM
cprgmr's Avatar
cprgmr
Default Re: Coolant pump install? (Strick)
:flag :flag :flag
I just got done removing the H20 pump and cleaning it all up. I would definitely use thread sealer on the bolts (I am). As far as the gaskets go, you should be able to use them without the aid of Permatex. :cheers:
Old May 12, 2003 | 01:43 PM
JayH's Avatar
JayH
FWIW, I always use gasket sealer on both the bolts and the gaskets.
Jay
To Coolant pump install?
