Fuel injector size recommendations?
Old May 11, 2003 | 04:51 PM
Dr. Doom's Avatar
Dr. Doom
Default Fuel injector size recommendations?
I wasn't planning on doing my stroker motor until later in the year. However, since my recent clutch problems, I think I am just going to start now. I am going to do a 388 build-up on my '94 LT1. I have most all the parts except a few components- one of which is fuel injectors. What size would you recommend? 30lb or 36lb? Is there a standard(lbs to cubic inches). Any help is always appreciated.
:cheers:
Old May 11, 2003 | 05:10 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Fuel injector size recommendations? (Dr. Doom)
I would start with 36's. I'm looking at going with at least a 30 for my 350 because the duty cycle is far too high with my current 24's. Knowing the duty cycle of my 350 I couldn't imagine running anything less than a 30 on a stroker. Of course cam choice is greatly going to affect fuel requirements.
[Modified by Nathan Plemons, 4:11 PM 5/11/2003]
Old May 11, 2003 | 06:35 PM
JAY87GTA's Avatar
JAY87GTA
4th Gear
Go by what kind of HP you anticipate making. For example, my engine DD2000 predicted 500hp. I never saw that, never got a chance to get the tune right. Anyhow, I did get it to run a 13.6@105, and was spraying a 150 dry shot to go 12.55@117. That was all on street tires, so the car should have run much quicker. I was running 30lbs FMS injectors with about 45 lbs of fuel pressure.
Old May 11, 2003 | 07:52 PM
ZD1's Avatar
ZD1
It is ONLY dependent on HP (intake/head flow). If your going to keep the same head stick with the current ones, but keep the fuel pressure as is. This of course you're the first person on this forum not to have project creep and end up with a work in progress...like me!!!!!!!!!!!!
Old May 11, 2003 | 08:14 PM
vader86's Avatar
vader86
Usually, you go with at least #30s on a 383.
I guess it would depend on whether your intake/heads are ported out and the cam youre running.
Old May 11, 2003 | 11:19 PM
Black87c4's Avatar
Black87c4
Default Re: Fuel injector size recommendations? (vader86)
I think 36# injectors is overkill for a 383.
http://www.efi-tuning.org/forum/inde...ac3341f9198c30
and http://www.thirdgen.org/techbb2/show...5&pagenumber=1
The thirdgen post is very long, ski's is a 11 sec 406.
[Modified by Black87c4, 10:25 PM 5/11/2003]
To Fuel injector size recommendations?
