Caused any damage? Loose spark plug
Old May 12, 2003 | 11:30 AM
enhance's Avatar
enhance
Default Caused any damage? Loose spark plug
After changing my oil today I noticed one of my spark plugs moving around while the engine was on.
It was pretty loose.
I took it out and it looked fine so I re-installed it.
Could this have caused any damage? I don't know how long I've been driving around with it like this.
Old May 12, 2003 | 11:44 AM
John Row's Avatar
John Row
Default Re: Caused any damage? Loose spark plug (enhance)
You might have worn the threads a bit. Keep checking the plug to see if it comes loose again.
Two of mine have come loose in the past couple of years, but I caught them fairly shortly after a plug & wire replacement. No damage that I can see, so far.
Old May 12, 2003 | 12:11 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
You should be OK. I had the same thing happen to me twice before I removed the heads. I saw nothing abnormal when I had the heads off. :cool:
Old May 12, 2003 | 02:37 PM
enhance's Avatar
enhance
Thanks, :cheers:
At least some good news today.
see
http://forums.corvetteforum.com/zerothread?id=559602
To Caused any damage? Loose spark plug
