LT4 vs LT1
Old May 12, 2003 | 01:04 PM
rmd8136's Avatar
rmd8136
Default LT4 vs LT1
My friend owns a '96 LT4 6 speed and I own a '95 LT1 automatic. The LT4 is listed at 330 hp at 5800 rpm vs the 300 hp LT1 at 5000 rpm. Which car has a faster top speed?
Also is the LT4 actually a stronger engine? Can the LT4 see 5800 rpm practically at top speed?
Old May 12, 2003 | 01:08 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: LT4 vs LT1 (rmd8136)
Maybe this will help: http://corvetteactioncenter.com/specs/1996/lt1lt4.html
Old May 12, 2003 | 01:23 PM
LT4POWR's Avatar
LT4POWR
LT4.com has some of the info you need.
Top speed (if both stock)...the 6sp LT4 will kill the A4 LT1.
Old May 12, 2003 | 03:22 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: LT4 vs LT1 (LT4POWR)
:iagree:
Old May 12, 2003 | 04:46 PM
vader86's Avatar
vader86
LT4 would probably have the higher top speed, but dont remember if anyone has even tried testing that.
LT4 is rated at 330, but actually puts 300 at the rear wheels, which makes it more like 345-350 at the crank.
GM underrated it, so as not to **** off C5 owners who had the 345hp LS1 in 97.
Old May 14, 2003 | 11:53 AM
cire96's Avatar
cire96
First piece of advise: Don't race your friend. His 330 HP number is actually a conservative measure. His LT4 will likely dino 300 at the rear wheels. And yes, (assuming he's gutsy/crazy enough) it will pull the red line in fifth gear, topping out in the 170+ range.
The LT4 was created by GM in 1996 as a way to insure that the last year of the C4 run would sell in light of everyone's knowledge that the LS1 was a 345 HP engine.
It was built on the LT1 block, with modifications to the crank (to make it stay together at 6,300 RPM's....was given a bigger cam, 1.6:1 ratio Crane roller rockers, and different heads. After the GM engineers finished up, they found that the engine overshot the + 30 HP goal, so they installed a set of intake maniffold gaskets that block a portion of the intake ports. Replace those with the non blocking variety, and it'll dino past the early LS1's numbers.
Hope this answers your questions. Cire96
Old May 14, 2003 | 02:29 PM
96GS#007's Avatar
96GS#007
Default Re: LT4 vs LT1 (cire96)
:bs Swap from the stock p/n 12528884 gasket to the GMPP p/n 12367777 gasket and you'll get the same hp result. Why? Not only does the gasket block the port on the cylinder head, but so does the INTAKE manifold. That's right folks, the ports are not matched even though the LT4 has a specific intake.
If you look close in the photo below, you can see how much material I removed from the intake to match the "77" gasket. There's still a lot more to remove from both the intake and the cylinder heads to precisely match the ports.
Stock, as delivered, production intake gaskets and all LT4s consistently dyno 290 - 305, which is roughly 340-350 at the flywheel. Mine was an even 300, down to the paper air filter element.
During the ZR-1/GS Gathering at the NCM a couple years ago, John Heinricy said the LT4 was a legitimate 350 hp engine as delivered. It was a Marketing decision to advertise it as 330hp. No mods were made to the engines to "detune" them.
Old May 14, 2003 | 06:28 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: LT4 vs LT1 (96GS#007)
I keep saying the same thing but no one believes me. You would need to port the intake allot. I can tell you from first hand experience not what i heard. Soem of us try to get some solid info to people and they blow it off.
So go ahead and just change that gasket, i heard it will give you 30+ HP as stated by some. :lol:
[Modified by ConeKLR, 6:30 PM 5/14/2003]
To LT4 vs LT1
