AC control readout???
Old May 12, 2003 | 05:29 PM
The13Bats's Avatar
The13Bats
Default AC control readout???
On my 86 the AC seems to work just fine but on the AC control if I push the ext temp switch it either rears the outside temp or 60 the 60 never changes...what's it's suppose to be giving the reading of?
Thanks, C
Old May 12, 2003 | 07:24 PM
don hall's Avatar
don hall
Default Re: AC control readout??? (The13Bats)
I'm not sure what A/C system you have, but one control should access the outside temp, and on control should set the desired in-car temp. A constant 60 reading indicates a fault.
Try this: push and hold the fan "up" arrow and fan "down" arrow at the same time for a few seconds (5). The display should show "00". Push "AUTO FAN" and the display will show any fault codes stored. If you have a code(s) displayed, post the number, and I will email you the code descriptions...........
Old May 13, 2003 | 02:37 AM
The13Bats's Avatar
The13Bats
Default Re: AC control readout??? (Oldman)
I assume this is the basic digital AC control...I'm new to the c4 thing...
I held both arrows and the "60" went to "00" I hit auto fan but all it did was return to "60" after a few seconds.... :confused:
Thanks,C
Old May 13, 2003 | 10:23 AM
don hall's Avatar
don hall
If the A/C is providing you with the desired temp without showing a correct reading, I would accept what you have. The problem may be with the HVAC programmer, and the diagnostics are quite complex, and I would imagine, quite expensive.
Old May 13, 2003 | 12:55 PM
SunCr's Avatar
SunCr
Dash Assembly temp reading for a/c & heating ranges from 60 to 90. If everything works, but all you have is 60, assembly needs to be replaced.
Old May 13, 2003 | 12:59 PM
The13Bats's Avatar
The13Bats
Default Re: AC control readout??? (SunCr)
Do you mean the AC control panel, as in the problem is within it?
I guess I'll live with it as long as the AC works.....here in FL I don't need the heater too much....
Thanks, C
Old May 13, 2003 | 01:21 PM
SunCr's Avatar
SunCr
Yep, the one in the dash.
To AC control readout???
