u-joint strap torque#
Old May 14, 2003 | 11:43 AM
Curveit's Avatar
Curveit
Default u-joint strap torque#
Can anyone tell me what to torque the u-joint strap bolts to, on the half-shafts? My Haynes says 150, and that seems a bit much, considering the drive shaft only calls for about 25. Thanks in advance.
:chevy
Old May 14, 2003 | 02:43 PM
JayH's Avatar
JayH
Default Re: u-joint strap torque# (Curveit)
My Haynes says 150
foot pounds or inch pounds? 12-15 foot pounds sounds about right, but I don't have the specs in front of me, sorry.
Jay
Old May 14, 2003 | 06:46 PM
1MoorTym's Avatar
1MoorTym
According to spicer 13-18 ft lbs.
Old May 14, 2003 | 09:16 PM
Curveit's Avatar
Curveit
It implies 150 ft./lbs but that seems like way too much. The car's an '86 by the way.
Old May 14, 2003 | 10:08 PM
CFI-EFI's Avatar
CFI-EFI
Or, tight, with a standard open end or box end wrench. While there is a spec for the torque, these aren't head or rod bolts. All the strap does is keep the u joint cap from sepatating from the yoke. The tab in the yoke keeps the cap from coming off the end of the u joint spider, and the yoke itself transfers the torque from the joint. You just don't want the bolt to back out.
RACE ON!!!
1984 Crossfire
Member NHRA
Old May 15, 2003 | 01:07 AM
Oly's Avatar
Oly
I put a little locktite/thread locker on the threads, 1 drop will do. The service manual says 18 lb. ft. torque.
Old May 15, 2003 | 01:55 AM
zog's Avatar
zog
Default Re: u-joint strap torque# (Oly)
I just replaced the ujoints, hubs, brakes, shocks and NOTHING had a torque of 150 foot lbs...even the spindle nut is only 81 lbs....I can't find the torque setting anywhere, but I was tightening the ujoint strap with an 8 mm socket and split the side of the socket using only my bear hands...probably less than 50 lbs with a 3/8 drive ratchet...must be 150 inch pounds I would guess... :smash:
Old May 15, 2003 | 07:08 AM
pablocruise's Avatar
pablocruise
Default Re: u-joint strap torque# (zog)
I've split a 5/16" socket.
What is the actual socket for those caps anyone? I have rounded some heads(and I wasn't cranking on it)
:confused:
Old May 15, 2003 | 11:31 AM
JayH's Avatar
JayH
Default Re: u-joint strap torque# (89 Paul in Cal)
A six point, 8mm socket has always worked perfect for me.
Jay
Old May 15, 2003 | 11:37 AM
Curveit's Avatar
Curveit
Thanks for your answers thus far.
Oly...Ialways use Locktite, Blue in this case
Zog...You might want to recheck that spindle nut, It goes 166, and some say 200Ft/Lbs.
The bolt is 8MM, but I think it's the same as 5/16
:chevy
Old May 16, 2003 | 01:05 AM
Curveit's Avatar
Curveit
How about some of you Drag racers, you guys just use 18 Ft/Lbs? On all other cars I'd just use a little Lock-tite, and tighten them good with an open-end, but I figured these Half-shafts might need a little special attention. Again thanks for all your answers.
:chevy
Old May 16, 2003 | 09:14 AM
Corvette0096's Avatar
Corvette0096
I just pulled mine off and there was some lock tight from the factory. I bought some green locktight and that set up to fast. So I have to use some red. I use the vien in the forhead trick as soon as you get one to pop out you have it tight. :)
Old May 28, 2003 | 05:33 AM
zog's Avatar
zog
Hi Curveit
Where did you see 166 pounds....I have two different manuals that both say less than that ...I sure don't want the hubs coming off at 100+mph...thanks for the warning....zog
Old May 28, 2003 | 11:01 AM
scorp508's Avatar
scorp508
Just hand tight with some locktite and you'll be good to go. :) Make sure you wire wheel the threads before reassembly to get any old locktite out. They go in soooo much smoother. :)
Old May 28, 2003 | 11:49 AM
Cap'n Rich's Avatar
Cap'n Rich
You can find common bolt torque recommendations at [URL][http://dodgeram.org/tech/specs/bolts/SAE_bolts.html/URL]
5/16" x 18 TPI is 18 ft/lbs (216 in/lbs) - however this is calculated on steel threads. Aluminum will always be less.
Of course you can always use the racer's setting - tighten it until it strips, then back out 1/4 turn. ;)
Rich
[Modified by Cap'n Rich, 9:09 AM 5/28/2003]
Old May 28, 2003 | 11:58 AM
NavyVet's Avatar
NavyVet
Default Re: u-joint strap torque# (Cap'n Rich)
Agree with the above - about 18-20 ft lbs for the u-joint retainer bolts - cleaned with a dab of Loc-tite blue.
Rear stub axle retainer nuts are 36mm - According to factory (Helms) manual - torque to 166 ft lbs. Anything less is asking for trouble.
Has anyone seen a GM bulletin that raises this number to 200 ft lbs? There has been mention in several threads, but I won't change the way I do it unless I have factory verification. I called 2 dealers that sponsor Corvette Clubs and their Service Managers knew nothing.
To u-joint strap torque#
