Coil over shock?
Old May 14, 2003 | 09:48 PM
nopain1984's Avatar
nopain1984
Default Coil over shock?
Is anyone running these?Did you have to beef up the mounts?Who makes the best set?(DRP)How does the ride compare to fiberglass springs?
Old May 14, 2003 | 10:11 PM
don hall's Avatar
don hall
Default Re: Coil over shock? (nopain1984)
There is an article on this subject in the July-2003 issue of Corvette Fever: "10 Tips To Better Handling", page 64.
Old May 14, 2003 | 10:35 PM
nopain1984's Avatar
nopain1984
Default Re: Coil over shock? (Oldman)
JUST read it.Doesn't say much.Any one out there have this system? :chevy
Old May 15, 2003 | 12:47 AM
vader86's Avatar
vader86
I believe zelement has it on one of his, run a search.
Old May 15, 2003 | 10:28 AM
johncazin's Avatar
johncazin
Default Re: Coil over shock? (vader86)
great set-up for the track, because it allows quick spring changes and weight jacking, using a wide variety of spring choices; no benefit for the street, as it increases unsprung weight.
To Coil over shock?
