cooling fan
Old May 15, 2003 | 10:07 PM
blackvette89's Avatar
blackvette89
Default cooling fan
my ecm will run my cooling fan at 336 degrees. i tried gounding the sensor on the block. i replaced the relay on the left fender. there is only one. none at the radiator shroud. any suggestions where the other relays are or how to diagnose why fan is not coming on in 220 degrees as before? :banghead:
