whining sound from somewhere..
Old May 16, 2003 | 02:57 AM
devilfish's Avatar
devilfish
Default whining sound from somewhere..
I noticed a whining sound from the engine area. Sounds like a supercharger but more quiet. It comes and goes.
I thougt it could several thing.
Alternator?
Waterpump?
Power steering pump?
AIR pump ( mine is gutted, but where rotating smooth when I turned it by hand )
What usual can make this sound?
Old May 16, 2003 | 05:59 AM
Mini_K's Avatar
Mini_K
Default Re: whining sound from somewhere.. (devilfish)
mine does the same thing... hope someone knows :confused:
Old May 16, 2003 | 08:19 AM
NUckINg FuTS's Avatar
NUckINg FuTS
Alternators whine when they're about to go out :yesnod:
Old May 16, 2003 | 08:22 AM
Atok's Avatar
Atok
Default Re: whining sound from somewhere.. (Mini_K)
Do you have a ZF 6-speed transmission? If so try pressing the clutch, it will probably go away. Mine does the same, and you're right it sounds exactly like a quiet super charger. It's the ZF you're hearing and according to my dicussions with ZF North America and Rockland Standard Gear this is a normal sound, nothing to worry about. A friend of mine has a '94 and makes the same sound. Most people don't even notice it.
:cheers:
Old May 17, 2003 | 01:54 AM
devilfish's Avatar
devilfish
Default Re: whining sound from somewhere.. (Atok)
no its not the ZF. Still got the whine with clutch engage.
My bet is the alternator, but the strange thing is that I dident got the whine before i did my topend job ? Could the alternator be out of aligment?
My other bet is my gutted AIR pump. Could it make more noise now when the pipe going from the AIR pump is remowed?
Old May 18, 2003 | 08:53 AM
devilfish's Avatar
devilfish
tt
Old May 18, 2003 | 09:57 AM
92corvette's Avatar
92corvette
Nobody can diagnose what this is on this forum.
It could be any of the things you mention but you have to get under the hood to figure it out.
Go get a mechanic's stethascope and listen to the moving components.
It will take you about 15 seconds to know where the whine is coming from rather than waiting another day for someone to 'guess' in this thread.
Old May 18, 2003 | 10:00 AM
Nathan Plemons's Avatar
Nathan Plemons
Maybe you've got a bad muffler bearing.
Old May 18, 2003 | 01:05 PM
devilfish's Avatar
devilfish
Default Re: whining sound from somewhere.. (Nathan Plemons)
k
I whas just thinking of the muffler bearing :crazy:
Old May 18, 2003 | 09:18 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
time for you guys to step out of the shadows and move up to the only modification you'll ever need.........
See below ;)
Old May 19, 2003 | 04:12 AM
white90conv's Avatar
white90conv
On my '90, the A/C compressor has a significant whine. It seems to vary a bit with outside temperature and goes away completely when the A/C compressor is turned off. This has been a long term thing so the compressor is not destroying itself.
Old May 19, 2003 | 05:05 AM
devilfish's Avatar
devilfish
Default Re: whining sound from somewhere.. (white90conv)
the A/C isent on.
Old May 19, 2003 | 05:55 AM
pablocruise's Avatar
pablocruise
Mine had a bad rear bearing in the alternator one time. Sounds like you say. You could actually see the ball bearing falling apart on the back of the alternator.
How 'bout a vacuum leak? Maybe you missed a line?
or maybe somebody put a supercharger on your engine and you didn't see them. :D Do feel alot of extra power? :D :lol: J/K :jester
[Modified by 89 Paul in Cal, 2:58 AM 5/19/2003]
Old May 19, 2003 | 05:59 AM
black bart's Avatar
black bart
I have never been to Stockholm before so if you are willing to pay for my round trip airfare I will find your noise for you. :yesnod:
[Modified by black bart, 6:01 AM 5/19/2003]
To whining sound from somewhere..
