Headlights?
Old May 16, 2003 | 09:58 PM
CENTURION's Avatar
CENTURION
Default Headlights?
One of them stuck on the way home, I turned the **** on the cylinder and it started working. What's the secret to these?
Old May 16, 2003 | 10:15 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Headlights? (CENTURION)
Vette Mag, had an article about rebuilding these....I don't know maybe 3 months ago...
it was truly helpful....
tony
:smash:
Old May 16, 2003 | 10:16 PM
oldace84's Avatar
oldace84
Vette Mag, had an article about rebuilding these....I don't know maybe 3 months ago...www.vetteweb.com
tony
:smash:
Old May 16, 2003 | 10:18 PM
oldace84's Avatar
oldace84
Default Re: Headlights? (oldace84)
Opp's....sorry for double trouble.....
tony
:eek: :eek: :eek: :eek:
Old May 17, 2003 | 05:52 PM
CENTURION's Avatar
CENTURION
Thanks for the reply, ther's a couple good vette shop in my area and they gave me reasonable repair prices. My friend has a C-3 he did a nice stationary headlight conversion with the smoked plexiglass lenses, it almost looks factory.
Thanks.
Old May 18, 2003 | 08:10 PM
LaVidaLoca's Avatar
LaVidaLoca
There have been several threads on this topic recently. Do a search on headlights. Some of the info is very good.
With headlights you have to specify the year since the assemblies changed over time. I see from your profile you have an 88. These have an electonic control which is pretty reliable, so the problem is likely in the motor. Since it starts up when you turn the ****, I would suspect the brushes in the motor. Check them out and use some light emory cloth to clean the armature. Should get you running again.
I have been looking for a rebuild kit for the headlight motors and have not been successful. If your brushes are bad you will have to replace the motor.
To Headlights?
