FRONT SUSPENSION
Old May 16, 2003 | 11:29 PM
Jerry D's Avatar
Jerry D
Default FRONT SUSPENSION
I have a 1986 that sits very low in the front and scrapes on the slightest incline. Does anybody know How to determine if the front leaf spring is worn out. Should only a new spring installation be considered or is a used spring worthwhile? I have heard that the aftermarket springs are problamatic.
[Modified by Jerry D, 4:32 AM 5/17/2003]
[Modified by Jerry D, 4:34 AM 5/17/2003]
Old May 16, 2003 | 11:41 PM
Jerry D's Avatar
Jerry D
Default Re: FRONT SUSPENSION (Jerry D)
Doesn't anyone know about Leaf springs? ;)
[Modified by Jerry D, 4:41 AM 5/17/2003]
Old May 16, 2003 | 11:58 PM
Jerry D's Avatar
Jerry D
Let's try again PLEASE!
Old May 17, 2003 | 12:06 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Hey Jerry D,
I wish my front end was low..........did you figuer out if it was the spring...if I were you I would leave it alone...just get new shocks (Koni's)...and set it up to get the best attitude...we're all after that.....
tony
:cool:
Old May 17, 2003 | 12:13 AM
vader86's Avatar
vader86
The only way it should be sitting too low is if the front spring is delaminating. You can get under there and youll see it cracking if that has happened. Only way to fix is replacement, shocks going bad can cause it to lower somewhat also but its mainly the spring.
To FRONT SUSPENSION
