When you use a separate battery to power the scanner and get , "No Data", this is a symptom that the ground connection on the ALDL is open. If the ground is open, your scanner should work ok when you power it up with the cig lighter.
Looking into the ALDL connector under your dash, the top right pin is ground and you can verify this with an ohmeter. The schematic shows this pin goes to engine ground but there is no description where.
Sometimes the ALDL pins become loose in the connector and will push out when inserting a diagnostic connector. I like to put my finger behind the ALDL when I push the diagnostic connector in so I can see if any pins a pushing out. The ground pin seems to be the first to loosen. If it does want to push out and not make connection with your diagnostic connector, pull the ground pin and if the locking tang is still there, try bending it out a but so it will lock.
ok, i went under there with a multi meter before and it showed no continuity between the black ALDL ground wire and any other ground... seems like this is my problem, but would it also cause the car to run like crap?
my guess is yes, if the other grounds are messed up too.. i guess my next step is to trace that ground.. or just splice a new one in..
anyone else have any thoughts?
EDIT: ALDL ground and ECM ground both have no continuity to any other ground, yet they have continuity with each other.. looks like the harness is coming apart tomorrow!!
Ifalldata is correct because I don't have an '86 manual,your ALDL ground is
part of a major ground for ECM and MAF,it is G104,it is located below LH valve
cover at rear of engine,but ground circuit for ALDL has connectorC237 behind
RS of I/P,near dash grommet,so if car runs ok then you probably have prob-
lem at that connection
yeah, that's what Mitchell's says.. it says that the ECM, ALDL, MAF, and Fuel pump relay ALL use the same ground
now, the mass air ground has continuity to other grounds.. BUT the ECM and ALDL don't... so im guessing there's a split in the wire between those two, and the MAF/FP... would that make sense? :banghead:
