Digital, Remote Fuel Pressure sender question :
Old May 18, 2003 | 12:48 PM
MrNuke's Avatar
MrNuke
Default Digital, Remote Fuel Pressure sender question :
I have a remoted, electronic Fuel Pressure sender and gage that I will be hooking up to my car.
Problem I found is that I have the superram installed, and can not get the FP Senderto plug in. The plenum is in the way.
Anyone have a solution to this they came upon? Or am I going to have to wait on the installation until I take the superram off again?
Thanks. :cheers:
Old May 18, 2003 | 12:53 PM
scorp508's Avatar
scorp508
Default Re: Digital, Remote Fuel Pressure sender question : (MrNuke)
Hmm? How are you trying to hook it up? My sender unit wasn't even the right threads to go to the schrader valve. Mine is off of a couple of adapters forming an elbow.
Old May 18, 2003 | 12:55 PM
MrNuke's Avatar
MrNuke
Default Re: Digital, Remote Fuel Pressure sender question : (scorp508)
I was wondering about going that way.. Maybe I'll visit HomeDepot.
Only thing is I don't want to use Teflon Sealer on the threads anywhere in the fuel system. Did you get special adapters to form the elbow? got a pic? :D
Old May 18, 2003 | 12:57 PM
scorp508's Avatar
scorp508
No teflon no nothing!!! If your sender is like mine it gets its ground from the fuel rail and needs to have clean thread to thread contact. I have a pic somewhere. I got them from summit, I think they are Aeroquip fittings or something like that.
Old May 18, 2003 | 12:59 PM
MrNuke's Avatar
MrNuke
Ohh ok cool..
So did you remove the shreader valve itself, and put a fitting inside, then added a 90Degree elbow and then threaded the remote FP sender in there?
Thanks for the info by the way
Old May 18, 2003 | 01:01 PM
scorp508's Avatar
scorp508
I removed the core only. Then there is a female to female adapter, a 90* elbow and then a female to female adapter to change threads to the sending unit.
Old May 18, 2003 | 01:04 PM
MrNuke's Avatar
MrNuke
ty :cheers:
Old May 19, 2003 | 03:57 AM
gcrouse's Avatar
gcrouse
I used a 90* female-female with swivel ends, then the adapter. Got Aeroquip stuff from my local Loper's Performance. Here's the pic... and it will fit with the SuperRam I'm currently installing.
Old May 20, 2003 | 07:45 PM
MrNuke's Avatar
MrNuke
Default Re: Digital, Remote Fuel Pressure sender question : (gcrouse)
Thansk for the pic.
Now do you guys replace the actual shraeder valve? As I see it has a pin that has to be pushed in to get the FP through it. I presume the first adapter replaces the actualy shrader valve. right?
Old May 20, 2003 | 07:48 PM
Nathan Plemons's Avatar
Nathan Plemons
I've got a braided line coming off of my fuel rail and running around the engine compartment to a better location for the sending unit.
Old May 20, 2003 | 08:34 PM
scorp508's Avatar
scorp508
Found mine. Don't pay attention to the teflon paste on there. That was from before I knew the unit got its ground from the rail. :crazy:
Mine requires removing the core of the schrader only. I'm going to do something this year so that I can have the scrader, my nitrous hookup, and the FP sender.
Old May 20, 2003 | 08:55 PM
bill mcdonald's Avatar
bill mcdonald
Mine is like gcrouse, and I have the super ram.
Old May 20, 2003 | 11:25 PM
gcrouse's Avatar
gcrouse
You remove the valve stem from the inside (same tool Discount Tire uses); because obviously the fuel can't exert pressure on your sender with the valve in there. But you leave the outside; the adapter screws onto it.
Old May 21, 2003 | 10:48 AM
MrNuke's Avatar
MrNuke
Thank you everyone.... :cheers:
To Digital, Remote Fuel Pressure sender question :
