LT1 Distribution
Old May 18, 2003 | 12:55 PM
FD2BLK's Avatar
FD2BLK
Default LT1 Distribution
Distribution
I am getting ready to drop in my LT1 and need some advice on the distributor. I got the motor out of a running F-body and rebuilt it (and a couple of goodies Hotcam, Ported heads/intake, electric water pump) any way I am going to replace the distributor. My question is I can get the dist for $145 without the module, can I reuse my module with ant reliability?
Old May 18, 2003 | 06:04 PM
sumoboy's Avatar
sumoboy
Default Re: LT1 Distribution (ejfagala)
I would replace the complete dist. It's not worth going back to replace it after what your doing. Why put an old used part (opti) back on a rebuilt engine and have to tear it apart if it becomes a problem. It's not like the top mounted dist. which is a easy fix.
Old May 18, 2003 | 07:07 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT1 Distribution (sumoboy)
:iagree:
Old May 19, 2003 | 12:22 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Opti's are more in the $400 range, unless you have one of those conversions to use a standard distributor.
To LT1 Distribution
