Thanks to Flame Red for O2 sensor tech tip =>
Old May 18, 2003 | 07:20 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default Thanks to Flame Red for O2 sensor tech tip =>
For a while I've had poor O2 sensor performance, since I put the long tubes in. So I used Flame Red's tech tip for installing a heated O2 sensor to replace a single wire setup. Great tech tip wih part #'s and easy to follow how-to. Long Tube header owners, check it out. I will look at my readings early this week with Tech 1A to see if it helped.
Thanks Flame Red (Bruce).
Old May 19, 2003 | 01:47 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: Thanks to Flame Red for O2 sensor tech tip => (Ski2Tee)
Where did you tap for power with the new heated o2? :cheers:
Old May 19, 2003 | 06:01 AM
pablocruise's Avatar
pablocruise
another thanx from me too. I tapped power from the windshield wiper motor wires.
Another good thing for ZF6 owners, is to mount the O2 sensor the passenger side collector. Way more room over there.
Old May 19, 2003 | 08:03 AM
LD85's Avatar
LD85
Default Re: Thanks to Flame Red for O2 sensor tech tip => (89 Paul in Cal)
Which color of feed wire on the wiper and which plug, please?
Old May 19, 2003 | 08:37 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Thanks to Flame Red for O2 sensor tech tip => (ld85)
I was tied into that wiper motor with my WB circuit for a while, until I mounted a painless wiring 7 fuse block.
The problems and the reason I did not like the wiper motor connection spot was every time I would flip my wipers on the wb would go blank for a while, like the power was cut for a second.
If your looking to connect, or have some things to connect for accesories, the extra fuse block is the right way to do it, and the safest for components.
Heated o2 is the ticket for the headers through :cheers:
Old May 19, 2003 | 01:18 PM
IBEAM700's Avatar
IBEAM700
Good info Thanx :thumbs: I wonder if this will help at all with the CA. smog test. I would think the heated O2 would give a more accurate reading than the non-heated
Old May 19, 2003 | 01:43 PM
LD85's Avatar
LD85
Default Re: Thanks to Flame Red for O2 sensor tech tip => (IBEAM700)
Well I just put a 5-AMP fuse in between the sensor and the feed line. Is a 5-AMP fuse too high?
Would the secondary fan relay be a better source for power? And which wire would it be? I dont have the battery hooked up yet and wont start the car till tomorrow.
[Modified by ld85, 1:56 PM 5/19/2003]
Old May 19, 2003 | 01:57 PM
IBEAM700's Avatar
IBEAM700
Are you using a switched power source? I would think you would have too or the O2 sensor would be hot all the time.
:cheers:
Old May 19, 2003 | 03:07 PM
LD85's Avatar
LD85
:cheers:
Well I just tapped into the Red 12V wire on the secondary fan, I assume that it is switched. Am I wrong?
Old May 19, 2003 | 03:34 PM
IBEAM700's Avatar
IBEAM700
I would think the fan would only get power when it was running. Id have to look at the service manual to find a switched source. Basically you want something thats going to be hot only when the ignition is in the on position.
Dont just tap off anything, you have to run the numbers to make sure the O2 sensor isnt going to pull to much power and blow your fuse.
:cheers:
Old May 19, 2003 | 05:41 PM
LD85's Avatar
LD85
Based on a CF search the amp draw is 1.2 - 1.8 amps. If there is a better place to get power I am open to using it.
Old May 20, 2003 | 12:24 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I went for the easy and obvious "hot in accy, run, bulb test" and pulled from the radio circuit. I do not currently have the radio installed. If adding the sensor heater to the circuit overcomes the 10amp fuse when the radio installed, well, I'll cross that bridge when and if I come to it. Plus if there is ever a problem with the sensor that causes the fuse to blow, I lose the radio and nothing else critical.
Old May 20, 2003 | 11:40 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Per Jeff Kopp, I tied my heated O2 to the Fuel pump relay. If engine is not running then O2 is not on. Working great. :cheers:
Old May 20, 2003 | 04:59 PM
IBEAM700's Avatar
IBEAM700
Default Re: Thanks to Flame Red for O2 sensor tech tip => (85vet)
:iagree: :thumbs:
Old May 20, 2003 | 06:18 PM
1MoorTym's Avatar
1MoorTym
:iagree: :thumbs:
The only problem with that is the total current draw is going to be pretty close to the 10AMP circuit max. I going to use a slight modification on that by using the fuel pump relay to trip a relay powered off the power distribution piont behind the battery.
Old May 20, 2003 | 07:03 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I am lucky, I installed Headman 1 5/8 full length headers and installed the O2 sensor just after the tubes meet and I have not had any problems yet.
Old May 21, 2003 | 12:21 AM
93LT1's Avatar
93LT1
What do you mean by poor O2 sensor performance? Where you running lean or rich until the car warmed up? Or was it alway inacurate? How did you determine the o2 was an issue?
Hank
Old May 21, 2003 | 01:00 PM
VMAX451's Avatar
VMAX451
Default Re: Thanks to Flame Red for O2 sensor tech tip => (1MoorTym)
Just for reference, my two 13190's pull 5.5 amps (combined) at key-on, which quicky drops to under 3 amps after a few seconds. I did it the way you plan, trigger a relay off a keyed circuit and draw power from the distribution point. Also use an in line fuse as close to the power block as possible, match the fuse size to the wire gauge that you are using.
[Modified by Vince Ivanc, 1:00 PM 5/21/2003]
To Thanks to Flame Red for O2 sensor tech tip =>
