what size weld wheels?
Old May 18, 2003 | 09:50 PM
madskilz's Avatar
madskilz
Default what size weld wheels?
Hey all,
I have a 96 LT4 (see sig below) and I am considering purchasing the following from a board member:
Rears (15x9) (Weld XP Prostars) (5.5 backspacing)
Fronts (15x5) (Weld Prostars) (3.5 backspacing)
He had them on his 87 C4 and had no problems with fit. I'm pretty sure the rears will clear (and I don't mind grinding the caliper a bit if I have to) but my concerrn is is the 15" clearing the front brakes.
Any thoughts or experiences?
Thanks!
Madhu
Old May 19, 2003 | 12:19 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: what size weld wheels? (madskilz)
I'm not positive, but I think you'll need more back spacing. I have 15 x 10 with 7.5 backspacing. This is on my '93 and what most of the others are using. Also some guys are using a 5/16 spacer as well.
The fronts should be OK, I have 15 x 3.5
Old May 19, 2003 | 06:08 AM
pablocruise's Avatar
pablocruise
Mad,
on my 89 I use 7.5" back spacing + 5/16 spacer and had to grind the calipers.
On fronts I have the J55 bigger 13" brakes/calipers and used also a 7/16" spacer + ground the calipers.
But I don't use the XP's. Maybe they are different.
I think I saw Beachbum Todd use XP's at the track one time. Maybe he will chime in here.
[Modified by 89 Paul in Cal, 6:27 PM 5/19/2003]
Old May 19, 2003 | 06:27 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: what size weld wheels? (89 Paul in Cal)
The fronts are fine with a 5/16" spacer for the larger 13" brakes. I think I an using a 7/16" spacer on mine with planty of extra clearance.
Old May 19, 2003 | 07:08 PM
AS84's Avatar
AS84
Default Re: what size weld wheels? (Vette92)
are you guys using longer studs? I have a pair of 15x10x6.5 draglites with 325-50-15 BFG's on my drag radial car....what are the chances they'll fit on my 90? Slim??
[Modified by AS84, 6:08 PM 5/19/2003]
Old May 19, 2003 | 07:49 PM
Red Rocket's Avatar
Red Rocket
Default Re: what size weld wheels? (AS84)
Use to have this same set up on the rear of my '94. Did have the longer studs in the back also.
Old May 19, 2003 | 08:27 PM
AS84's Avatar
AS84
Default Re: what size weld wheels? (Red Rocket)
hmmm, interesting......do the longer wheel studs interfere with stock style lug nuts on say...a gs wheel?
Old May 19, 2003 | 09:27 PM
pablocruise
oh yeah. I forgot about those. I am using the ARP's. The nuts that were included with my chrome 5 spokes are open ended acorn. They just had a chrome plastic cap covering the end. I didn't know this till I bolted them on and bottomed them out on the rim. The stud came poking out. The lock nuts I had a machine shop lathe off the ends so I could still have that security feature.
Use GM perf part # 22551491 studs. They are the longest.
also, the spacers do need to be 7/16" as Chris mentions above. I will edit my previous post.
Old May 19, 2003 | 10:21 PM
AS84's Avatar
AS84
Paul- so your studs are cut off at the " just right" length that allows you to bolt your street wheels on, with the theft preventative locks, yet long enough to give the support that the weld wheel needs? I would really hate to change out studs and then have to do some funky mods in order to get my other wheels back on.
BTW- thanks for the info
Old May 19, 2003 | 11:12 PM
Red Rocket's Avatar
Red Rocket
Used the stock lug nuts but drilled a hole thru the Black GS lug nut covers and paint the end of the stud black with the GS wheels on.
To what size weld wheels?
