PKE Programming
Old May 19, 2003 | 05:13 PM
stockred96's Avatar
stockred96
Default PKE Programming
I know that you have covered this but I can't seem to get my car to go into program mode. I followed the owners manual and everything is okay until I go to turn the key off. Then the Passive light goes out completely. I have tried only 1 click. My qustion is if there has been more than 3 remotes programmed is there a way to reset the system and start over again??? Any and all help would be appreciated!!! Thanks
Old May 19, 2003 | 06:03 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: PKE Programming (stockred96)
You just have to do as you are doing. I believe the max is 3 transmitters. The key shud be in the "run" position initially. When you turn the key to the off position, I believe it has to be the "lock" position.
Make sure any other transmitters are well away from the car.
Old May 19, 2003 | 08:22 PM
stockred96's Avatar
stockred96
Default Re: PKE Programming (lou sylvestri)
I'll keep on trying...Thanks
To PKE Programming
