Can I turn my engine backwards?
Old May 20, 2003 | 02:38 AM
gcrouse's Avatar
gcrouse
Default Can I turn my engine backwards?
Maybe a silly question.... I had it lined up at TDC #1 before removing the distributor. Then I found I needed the serpentine belt off; in pulling on the belt, I rotated the crank maybe 15-20* past TDC.
So can I just grab the crank pulley with the belt and move it backwards a little? Or do I have to spin it 2 full rotations forward and line it up again?
Old May 20, 2003 | 03:43 AM
bill mcdonald's Avatar
bill mcdonald
Default Re: Can I turn my engine backwards? (gcrouse)
You can spin it backwards.
I just throw mine in 5th gear and push it forward or backwards. I just remove the plugs so it does move.
Old May 20, 2003 | 04:17 AM
Darkness's Avatar
Darkness
Default Re: Can I turn my engine backwards? (bill mcdonald)
Yes of course. Done it several times.
Old May 20, 2003 | 04:49 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Can I turn my engine backwards? (Darkness)
Yup, sure can. Just doublecheck to make sure the car is in neutral (ask me how I know :bb )
Old May 20, 2003 | 09:44 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
no problem
Old May 20, 2003 | 05:57 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Can I turn my engine backwards? (joecaver)
Doesn't the motor spin backward when you put it in reverse? :hat
Old May 20, 2003 | 11:30 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Can I turn my engine backwards? (Vette92)
:lol:
You can't be serious???
Old May 20, 2003 | 11:36 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
ya just like you can take off miles in reverse Bueler anyone anyone???? :steering:
[Modified by crash1mac, 10:37 PM 5/20/2003]
To Can I turn my engine backwards?
