LT1 Dash Coolant Temperature Gauge
Old May 20, 2003 | 08:07 AM
Atok's Avatar
Atok
Default LT1 Dash Coolant Temperature Gauge
This is my first summer with my '95 LT1 Vette....
My dash coolant temperature gauge does not agree with the digital value on the dash. It appears to read 5 degrees celcius hotter. Is this normal due to the sensor being in the back of the head as opposed to the water pump for the CCM sensor?
I noticed this while idling in town today. It gradually heats up to approximately 110 on the digital and almost in the red zone on the gauge. Then the fans kick in and cool it down to 100 on the digital, but the gauge still shows quite hot. The fans are operating as they should be according to the service manual (on above 108 off at 105 or so). With A/C on the fans are running all the time in low speed so it stays cooler (correct according to service manual). Can someone confirm this temperature range is normal compared to their car?
Just wondering what gauge I should trust? I don't like it running so hot while idling so I may have to look into reprogramming the PCM to turn the fans on at a lower temp.
:confused: :confused: :confused:
Old May 20, 2003 | 08:12 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: LT1 Dash Coolant Temperature Gauge (Atok)
They should read fairly close but the analog gauge is not linear. Meaning halfway between 100 and 200 would not necessarily mean 150.
Old May 20, 2003 | 11:15 AM
Red Dwarf's Avatar
Red Dwarf
My 95 read the same way. Always has, not to worry.
Old May 20, 2003 | 01:43 PM
KurtK's Avatar
KurtK
It sounds closer than mine!
When I took delivery of my '94, there was a tag hanging from the steering column tilt lever that basically said the analog gauges were more or less guidelines, and the digital readout was the real info.
I probably have it in a bag somewhere, along with the window sticker and other delivery items ( including the questionnaire about the paint job)..
Old May 20, 2003 | 01:50 PM
BlackBeast2's Avatar
BlackBeast2
Default Re: LT1 Dash Coolant Temperature Gauge (KurtK)
I have only had my 95 for a few months. No papers, no books or manuals came with it. Its my first 'vette.
How do you get the temp to read digital ? I'll fool with it at lunch, but thought I would ask to.
Thanks guys. :cheers:
Old May 20, 2003 | 02:10 PM
9T4YY1's Avatar
9T4YY1
Go by the digital temp gauge. Analog sensor is placed somewhere else mine is allways pegged. Digital should not read over 230.
Old May 20, 2003 | 02:29 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: LT1 Dash Coolant Temperature Gauge (9T4YY1)
Mine's gone over 230 before....and it's about 15 deg off from the analog :D
Old May 20, 2003 | 05:15 PM
pwrful c4's Avatar
pwrful c4
On my 1994 i have a 10 degree variance. :steering:
Old May 20, 2003 | 06:01 PM
Atok's Avatar
Atok
Default Re: LT1 Dash Coolant Temperature Gauge (pwrful c4)
Thanks people, I feel better now. Man GM likes to run the LT1 hot! I wonder if that's the reason for the Mobile 1 oil requirement?
:cheers:
Old May 20, 2003 | 06:23 PM
BlackBeast2
:cheers:
..............And the change in design of the C5 cooling system.
Old May 20, 2003 | 08:26 PM
Timmy!'s Avatar
Timmy!
Default Re: LT1 Dash Coolant Temperature Gauge (BlackBeast2)
The digital gauge reads on one the radiator side of the waterpump and the analog gauge reads off of the coolant in the head or block. I know this because the relay went out for my electric waterpump which caused it not too work and the coolant on the digital gauge read like 90 degrees and the analog was completely pegged and I had steam coming out of my hood.
As soon as I hooked power to the pump and ran some coolant into the radiator, the digital gauge immediately read like 260...
Old May 20, 2003 | 08:38 PM
Darkness's Avatar
Darkness
Default Re: LT1 Dash Coolant Temperature Gauge (Timmy!)
:iagree: Sounds about right, becasue of the location of each sensor!
Old May 20, 2003 | 08:49 PM
Goody's Avatar
Goody
Default Re: LT1 Dash Coolant Temperature Gauge (Darkness)
Not sure about celsius, but my car normally runs at 197-201 will on the freeways. Gets hotter in the stop and go stuff. Fans perform as you previously stated by design. No worries.
Yes, hotter temps require Mobil1 oil. Also, it helps with emissions too. Emissions require a hotter engine to provide the best burn, heats oil up sooner to get rid of contaminates and heats the O2 sensors sooner for better fuel management ie...emissions.
To LT1 Dash Coolant Temperature Gauge
