Left headlight sometime doesn't work
Old May 20, 2003 | 01:10 PM
VQT88Vette's Avatar
VQT88Vette
Default Left headlight sometime doesn't work
I checked the connection about four times and also checked with the Ohm meter. Everything check out :confused: . The light works again each time I reconnected but won't work in about two-three weeks and I have to unplug and reconnect it again in order for it to work :confused: .
What is wrong with the electrical system? Do I need to replaced the wires?
Old May 20, 2003 | 04:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Left headlight sometime doesn't work (VQT88Vette)
It could be a problem in the socket or wiring.
I had an intermittent turn signal issue and finally traced the problem to some taped wires which revealed that a splice had only been twisted, not soldered together!
Old May 20, 2003 | 09:07 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Left headlight sometime doesn't work (65Z01)
Thanks 65Z01,
I'll trace it down a little more this weekend since I can't drive to BG for the Cruise in. If it the socket, which I checked it with the Ohm meter and no resistance, do you think Autozone/pepboy have those replacement ot Jeff Kopp/ Chris have it?
[Modified by VQT88Vette, 9:09 PM 5/20/2003]
To Left headlight sometime doesn't work
