GM's 4bbl carb intake for LT1's
Old May 20, 2003 | 06:12 PM
BlackBeast2's Avatar
BlackBeast2
Default GM's 4bbl carb intake for LT1's
Has anyone here, or known of, ever switched over to this carbed intake manifold set up that GM offers for the LT1 ?
Probably would require a lot of modifying to the stock system right? (aside from the obvious)
But, in a way, it might be :cool:
Obviously not for your average 'street' set-up.
http://www.jegs.com/cgi-bin/ncommerc...03&prmenbr=361
:chevy
Old May 20, 2003 | 06:17 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: GM's 4bbl carb intake for LT1's (BlackBeast2)
It allows you to use a carb and a standard distrbutor on your LT1. Essentially it would let you retain the benefits of reverse flow cooling without having to make the electronics work. It seems like something you would want to use in a street rod or anything else you didn't want to have to make computer controlled.
I don't think you can put it on a C4 with the stock hood.
Old May 20, 2003 | 06:49 PM
bill mcdonald's Avatar
bill mcdonald
I dont really know much about the LT1/4's as far as swaps go or them being remotly the same size intake, but I have seen an LT4 with the GM carb intake on it like that set up for EFI.
He used a C5 throttle body. He also had a tube made to fit under the hood and welded into a carb plate.
The dist hole was convereted over to a breather but it was puking oil on the autoX track. I think some sort of baffle would of solved that.
This car also had an electromotive tech 2 system on it, which gets rid of the Opti and replaces the computer.
I rode in it, and it pulled really hard, only other big mod on it were headers and exhuast. the internals of the engine were all stock.
Old May 20, 2003 | 08:32 PM
poweredbylt1's Avatar
poweredbylt1
Default Re: GM's 4bbl carb intake for LT1's (bill mcdonald)
i make that
[Modified by poweredbylt1, 1:37 AM 5/21/2003]
Old May 20, 2003 | 08:38 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: GM's 4bbl carb intake for LT1's (Nathan Plemons)
I didnt know there was a benefit to reverse flow cooling, didnt they switch back to the old style with block being cooled first?
:cheers:
Old May 20, 2003 | 08:44 PM
Nathan Plemons
Default Re: GM's 4bbl carb intake for LT1's (IBEAM700)
:cheers:
An LT1 block can easily run 12:1 compression on pump gas. It's an outstanding design but it just wasn't the same as anything else. I'm not sure if the LS1 is reverse flow or not, I know it also doesn't have any coolant running through the intake.
Old May 20, 2003 | 10:33 PM
bogus's Avatar
bogus
the advantage to reverse flow cooling is simple - reducing the expansion rates of the 2 divergent metals.
Aluminum and iron expand at different rates... the reverse cooling will not eliminate it, but will lower it.
To GM's 4bbl carb intake for LT1's
By Michael S. Palmer | 2026-06-03 11:00:24
