power door locks
Old May 21, 2003 | 08:50 PM
reagr1244's Avatar
reagr1244
2nd Gear
Default power door locks
I have a 95 C4 it sounds like the doors want to lock when I shut the drivers door after i get inside but they dont . Question is are they supposed to lock when I get in or reach a certin speed. Please help.
Ron
Old May 22, 2003 | 10:24 AM
comp94's Avatar
comp94
Default Re: power door locks (reagr1244)
my 94 does the same thing i still havent figured it out yet
Old May 22, 2003 | 11:44 AM
John Row's Avatar
John Row
How long does it take before you hear the noise?
Are you sure it's not the ABS doing it's self test? This happens at 3MPH and it's right behind the drivers seat.
Old May 22, 2003 | 05:35 PM
cdsmith's Avatar
cdsmith
Default Re: power door locks (John Row)
The pin switch probably needs adjusting. Mine did the same thing.
Old May 25, 2003 | 11:14 PM
comp94's Avatar
comp94
Default Re: power door locks (cdsmith)
how do i go about adjusting the pin switch
Old May 25, 2003 | 11:46 PM
tboo's Avatar
tboo
Default Re: power door locks (comp94)
Hey, mine does this as well. Perhaps this is why my PKE wont lock the doors-it will just unlock them.
Old May 26, 2003 | 12:31 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: power door locks (tboo)
If you get in the car, put the key in the ignition but don't start the car yet, and shut the door, the system will try to unlock the doors. If they're already unlocked, great. That's normal - it's part of the GM setup that tries to make sure you never lock your keys in the car. Then you can lock them with the door switch.
Upshot is - the doors won't stay locked on a shut-off car with a key in the ignition. The keyfob goes inactive after 15 minutes of motionlessness. If you lock your keys in the car, you can get it to unlock itself by shaking the car enough to reactivate the keyfob.
To power door locks
