Steering problem - rack or pump?
Old May 21, 2003 | 10:36 PM
mk2001c's Avatar
mk2001c
Default Steering problem - rack or pump?
Power steering on my 1996 isn't %100. During slow speed turns, it gets difficult to turn the wheel left and the car will groan. It's especially noticable when the fluid is hot (after an autocross run). The fluid has been flushed and changed recently and the car has the stock fluid cooler. Haven't noticed any leaks and the reservior is topped off. I'm wondering if it is my pump or steering rack. :nonod:
Old May 22, 2003 | 09:20 AM
Frodo's Avatar
Frodo
Default Re: Steering problem - rack or pump? (mk2001c)
I replaced the steering rack on my 89 coupe last year due to leaking seals. After a few months the new rack started doing pretty much what your rack is doing, except mine did it all the time. Hard to turn left with a groan, easy to turn right. Fortunately the rack was still under warranty so I replaced it again and all is well. So... I'd say it's your rack. Besides, the pump does the same work whether turning left or right.
Old May 23, 2003 | 04:54 PM
mk2001c's Avatar
mk2001c
Default Re: Steering problem - rack or pump? (Frodo)
Do you recommend a new rack or rebuilt? For rebuilts, what source?
To Steering problem - rack or pump?
