Security system problem in my 89
Old May 22, 2003 | 04:03 AM
tangogreg's Avatar
tangogreg
6th Gear
Default Security system problem in my 89
After the glass was replace on the driver's side I was unable to turn off the security by keying and entering from that side. Still works fine if I enter from the passenger side. Have the door panels off and cannot find anything disconected. How to track it down?
Old May 22, 2003 | 10:13 AM
doc's toy's Avatar
doc's toy
Default Re: Security system problem in my 89 (tangogreg)
You need to ck your switch which is located on lock cylinder,probably got
mislocated during window replacement,to do it use ohm meter connected to
switch connector,should show continiuty and go open when going from lock to
unlock or visa versa but should swow both
