1989 NORMAL OIL TEMP??
Old May 22, 2003 | 07:28 PM
CTYANK2's Avatar
CTYANK2
St. Jude 15 Year Donor
St. Jude Donor '07 thru '25
Default 1989 NORMAL OIL TEMP??
After warmed up my oil temperature seems to vary from around 180 to 235 degrees in outside temperatures from 55-75 degrees. What is "normal" for street driving - some highway/local but not stop/go traffic. The car is automatic and stock exept for the exhaust and ignition and doesn't have any extra fan or other cooling devices. Stock chip too. What temps are you running in similar engine/conditions?
Old May 22, 2003 | 11:33 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: 1989 NORMAL OIL TEMP?? (CTYANK2)
Mine is usually 10 to 15 over what ever the water temp is. :chevy
Old May 22, 2003 | 11:48 PM
vader86's Avatar
vader86
your temps sound normal, mine were that way before the fan reprogram and new stat
Ideally the oil temp will be 10-20F above water temp
Old May 22, 2003 | 11:50 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Both my C4s run oil temps 10-20 degrees above water temp after warming up.
Old May 23, 2003 | 05:51 PM
pascualjr's Avatar
pascualjr
Default Re: 1989 NORMAL OIL TEMP?? (VetNutJim)
:iagree:
Old May 24, 2003 | 09:39 AM
chucks88's Avatar
chucks88
Wait 'till you put the A/C on :eek:
Old May 24, 2003 | 11:05 AM
dppeaden's Avatar
dppeaden
Sounds correct. I run about the same.
To 1989 NORMAL OIL TEMP??
