How much engine power does alternator load consume?
Old May 26, 2003 | 03:00 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: How much engine power does alternator load consume? (jfb)
For $49.95 I don't want to know. :hat
Old Jun 1, 2003 | 05:27 PM
MrNuke's Avatar
MrNuke
Default How much engine power does alternator load consume?
:rolleyes:
Ok now that EVERYBODY has had a chnce to flex their brains, have any of those peope ACTUALLY run at the track without an AC or a disconnected AC? If NOT then I'd say *SHUSH* and let someone who actually tried it and knows first hand differences with it..
Listening to the 'people who know' on these 'smart' posts is like starting a thread about FTL travel. You may talk theoritical physics and dynamics all you want, but unless you went FTL *SHUSH*. :conehead
Old Jun 1, 2003 | 05:41 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: How much engine power does alternator load consume? (Dan Parker '96)
jfb has it nailed
I agree. All power has to have a source. On our Corvettes, that source is the engine. It takes engine horsepower to make electrical energy.
It ain't free.
Larry
code5coupe
:seeya
Old Jun 1, 2003 | 08:44 PM
neverendingproject's Avatar
neverendingproject
Default Re: How much engine power does alternator load consume? (rocco16)
jfb is right on about the alternator robbing more power when its load is greater . give you an easy to understand example. a gas powered generator. when you start it , it runs at a certain rpm. the more things you plug into it, the more it bogs down. really no difference between that and your car cept the generator has a much bigger load on it.
one thing i am mixed on. i personally believe that 160 degrees is too cold to keep cylinder temps optimal. however , when the thermostat it closed, it DOES take more power to turn the water pump. this is due to block pressure. to be specific. the waterpump is still trying to "pump" even though there is nowhere to pump the water to when the thermostat is closed. this creates pressure , which takes power to produce. how much power? i have no idea.
just my .02
Old Jun 1, 2003 | 08:58 PM
hippy's Avatar
hippy
Default Re: How much engine power does alternator load consume? (MrNuke)
:rolleyes:
FWIW I GTechd my old vette back in 98 with and without (1 run) the serpentine belt. Here was the difference. With the belt on my best qtr was 14.07. I probably made 10-15 runs that day trying to get under 14, so for one run I pulled the belt. Before belt removal you could full stall launch without tire squeal, after removal I did get slight squeal. That one run netted me a 13.96. I do believe this is what Mr. Nuke wanted for a response.
Old Jun 1, 2003 | 10:29 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: How much engine power does alternator load consume? (neverendingproject)
My coolant does not run 160 F with a 160 tstat. It indicates around 178 - 185 on average on the digital speedometer gauge indicator, and that's just *coolant* temp. Oil temps are the better indicator of cylinder temperature, of overall internal engine temperature. On average, my oil temps with the 160 stat are only about 12 degrees below what they were w/ the stock 180 stat. So the actual physical cylinder wall temps are probably somewhere below that differential, and I doubt it is enough of a difference from the stock condition to matter.
Also, this 12 degree average drop in oil temps also make it difficult for me to buy the theory that cylinder ring/wall wear is greater with a 160 stat installed. Does such a slight temp drop have any effect on the Mobil 1 synthetic oil's coefficient of friction (lubricity) and viscosity? Doubtful. I actually asked Mobil 1 tech about this exact situation and never rec'd an answer. Great tech support huh?
Old Jun 1, 2003 | 10:58 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: How much engine power does alternator load consume? (Lone Ranger)
Ok... I did the math and found out that the alternator isn't such a drag.
Using the equation P=IV (power in watts=amperage X voltage) we come up with this:
P=140amps(the max rating on the alternator) X 12 volts
P=1680 watts
1680 watts = 2.25 horsepower.
Now add in frictional losses and such and be conservative so let's double the HP draw plus some. We still come up with only 5HP to drive the alternator at full load.
Hopefully that answers the original post.
[Modified by Dan Parker '96, 9:59 PM 6/1/2003]
Old Jun 2, 2003 | 10:50 AM
Rich_01659's Avatar
Rich_01659
:rolleyes:
Do you run you 1/4 mile at 100% Efficiency - if you did you WOULD realize these losses. my guess is you lose more to bad shifts or spinning tires. just because YOU can't see it doesn't mean it is not real.
