Are These Tires Big Enough
Old May 24, 2003 | 12:32 AM
Irocan's Avatar
Irocan
Default Are These Tires Big Enough
I am going to get a pair of slicks. Going to get ET Drags but debating between 26x8.5x15 or 26x10x15.
These are going on my 88 L98 Camaro that so far has run 13.70's @ 102 mph. Haven't been able to come out of the hole very hard though even on the Nitto's. I want to use the slicks just for the track only.
Bob
Old May 24, 2003 | 12:34 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Are These Tires Big Enough (Irocan)
If you're still running the stock 10 bolt rear and you really have enough power to need slicks, I wouldn't put slicks on the car. You'll snap that rear end like a twig. Seen too many 10 bolts come apart on F-bodies
Old May 24, 2003 | 01:02 AM
Irocan's Avatar
Irocan
Default Re: Are These Tires Big Enough (CorvetteZ51Racer)
No, its the stock Borg Warner 9 bolt with 3.27 gears. Supposedly stronger than the 10 bolt. I just put a new posi unit it too.
bob
Old May 24, 2003 | 01:06 AM
Ray383's Avatar
Ray383
I thought the 10 bolt was the stronger of the two. I could be wrong.
Old May 24, 2003 | 01:20 AM
CorvetteZ51Racer
Default Re: Are These Tires Big Enough (Ray383)
No, apparently his car is either an IROC or has an IROC rear end, and the BW 9 bolt, aka the Australian 9 Bolt, is a much stronger diff than the GM 10 bolt. The 3rd/4th gen F-body 10 bolt only has a 7.5" ring gear...the same size as the 4 cylinder Fox body Mustangs.
Old May 25, 2003 | 10:00 PM
Irocan's Avatar
Irocan
I think I'm going with the et drags 26x10x15.
Bob
Old May 25, 2003 | 11:25 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
They may slow you down. Whats your 60'?
Old May 25, 2003 | 11:49 PM
Irocan's Avatar
Irocan
Default Re: Are These Tires Big Enough (mackeyred96)
The best I can get is a 2.0x. That is easying into the gas. I want to be able to come off the line hard. I think with good traction I should be able to to get a least a 1.90.
Bob
To Are These Tires Big Enough
