lt4 lt1
Old May 25, 2003 | 01:50 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Default lt4 lt1
ok i have a lt1 whats the difference from a lt4 what do i need lt4 cam, 1.6 rr,different intake?heads? are the bottom ends exactlly the same :confused:
Old May 25, 2003 | 03:58 PM
Half Fast's Avatar
Half Fast
Default Re: lt4 lt1 (fiberglasscoffin)
http://www.protechmachine.net/lt4/lt4.html
Old May 25, 2003 | 04:20 PM
fiberglasscoffin
Default Re: lt4 lt1 (Half Fast)
thanx. alot more then i thought
Old May 25, 2003 | 04:44 PM
vader86's Avatar
vader86
If you get a little head porting and the LT4 hotcam kit, youll be faster than an LT4.
Old May 25, 2003 | 05:09 PM
dizwiz24's Avatar
dizwiz24
attn: fiberglasscoffin
Make sure you know the LT4 hotcam kit, does not give you the LT4 camshaft.
The camshaft that is in that kit (the one from GM performance parts) is more radical (but still very driveable, even w/o chip changes on a 6spd, although a programming change will make it almost transparent) than the cam that comes on an LT4 engine.
Also, the LT4 hot cam kit seems to work better on 6 speed cars. Correct me if Im wrong but I believe automatics run the ZZ4 cam (one step less radical than the hotcam).
Old May 26, 2003 | 01:15 AM
fiberglasscoffin
Default Re: lt4 lt1 (dizwiz24)
is the hotcam not as good for nitrous?anyone using the hotcam and nitrous
To lt4 lt1
