Lock knob removal (need a little help)
Old May 25, 2003 | 02:51 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Lock **** removal (need a little help)
I'm removing the door panels to replace the outside weatherstrip (and lube and tighten the window works etc.) and need advice on the lock ****. The manual shows a screw behind the **** but I can't seem to get the **** out of the way. Does it pry off? If so, do I pry it away from the panel (towards me)? I'd hate to break that little piece of plastic.
Thanks in advance.
Old May 25, 2003 | 02:56 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Lock **** removal (Steel Blue 91)
On my '88 I put a small screwdriver behind the lock **** and pry gently till it pops loose; then push to the unlocked position and remove the ****.
Old May 25, 2003 | 03:05 PM
Steel Blue 91
Default Re: Lock **** removal (65Z01)
Thanks! That did the trick.
Appreciate the help.
To Lock knob removal (need a little help)
