Superram Likes Being Lean
Old May 25, 2003 | 10:49 PM
91superram's Avatar
91superram
Default Superram Likes Being Lean
Car runs stronger when I run It lean (42psi vacuum off)pull the plugs and the insulator is white if I rich it up a bit I seams to run fat and not as hard. Car still runs cool and dosent over heat what should I do?
Old May 26, 2003 | 08:28 AM
chucks88's Avatar
chucks88
Default Re: Superram Likes Being Lean (91superram)
They say Lean is Mean. I keep mine at 41 psi. In fact I had the pressure with my stock TPI intake at 41 psi also. Others have increased the pressure for more performance.
Old May 26, 2003 | 08:49 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
You really don' know if your lean, unless you have a WB02. How are you gaging it?
To Superram Likes Being Lean
