94 RPO difference?
Old May 26, 2003 | 08:15 PM
sumoboy's Avatar
sumoboy
Default 94 RPO difference?
What is the difference in the RPO G44 and G92? Mine shows both. I know it's a 3.07 for G44 but G92 is a 3.07 Rear Axle, Performance Ratio. :confused:
Old May 26, 2003 | 09:16 PM
95AquaC4's Avatar
95AquaC4
Default Re: 94 RPO difference? (sumoboy)
It should show both...the G92 is simply applying it has the performance ratio, the G44 indicates the ratio itself. I believe through the years there have been different "performance ratios". But the indication of the actual ratio is in a seperate RPO. Sounds confusing, but it's pretty easy.
[Modified by 95AquaC4, 6:05 AM 5/27/2003]
Old May 26, 2003 | 09:47 PM
Stingray1970's Avatar
Stingray1970
:iagree:
Old May 26, 2003 | 10:21 PM
sumoboy's Avatar
sumoboy
Default Re: 94 RPO difference? (95AquaC4)
Thanks for the replies. It was kind of confusing. :thumbs:
To 94 RPO difference?
