Smell gas?!
Old May 27, 2003 | 10:38 PM
Gregory VanLare's Avatar
Gregory VanLare
Default Smell gas?!
When I start up my 85 with a full tank I get a leak in the driveway. As the tank goes down there is less dripping. It appears to come from the back end (that's where the puddle was). I smell gas whenever I start it though. What should I do?
:confused: :confused:
Old May 27, 2003 | 11:07 PM
needanother1's Avatar
needanother1
What should I do?
I'd quit driving, or even starting the car until I fixed that fuel leak!
You don't even want to think about a gasoline fire back there...
And park outside.
The leak has to be coming from the tank itself or the fuel lines. If it was the tank, you shouldn't have to have the car running for it to drip--- it ought to drip all the time, or at least until the fuel level drops below the leak. Fuel line leak would get much worse when the fuel pump runs.
If you feel you can safely work around the car (with a fire extinguisher handy) you might drop the spare tire and crawl under there to have a look at the bottom of the tank and the fuel lines. You might be able to see where it's been leaking.
Jason
Old May 28, 2003 | 10:28 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Smell gas?! (Gregory VanLare)
Big red flag......please find out what it is......
Check everything back there.....maybe you overfill the gas tank??????
Just my thoughts........
tony
:smash: :smash: :smash:
Old May 29, 2003 | 06:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What should I do?
Don't drive it! It may be hard to track down evidence of a leak, because the fuel evaporates quickly.
I'd suggest bringing home some gas cans, and topping the car off while everything is unbolted from there, so you can see where it's leaking hopefully. Remember, you can run the fuel pump during this test without running the car.
To Smell gas?!
