95 LT1 Jacking question
Old May 28, 2003 | 09:45 AM
sundbergjc's Avatar
sundbergjc
Default 95 LT1 Jacking question
There's been numerous strings on this topic and a number of folks appear to advocate lifting an entire side by jacking the car at a point below about where the outside mirrors are. Is this really a "safe" place to jack, and where exactly should the jack be placed? This method sure would make the placement of jack stands easier.
Thanks. :skep:
Old May 28, 2003 | 09:27 PM
Marlin in Minn's Avatar
Marlin in Minn
Default Re: 95 LT1 Jacking question (sundbergjc)
If you click on "search" ( on the left side of your screen) then use keyword "jack", search both the c4 tech and c4 general forums, you'll find a whole bunch of topics to read on this subject. :cheers:
Oops. almost forgot....select the archived topics..
[Modified by Marlin in Minn, 9:30 PM 5/28/2003]
Old May 28, 2003 | 09:43 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I either jack where it says "place jack here" or as you will find in the search, you will see my other jacking locations and methods.
To 95 LT1 Jacking question
