Changing my own starter...
Old May 28, 2003 | 08:39 PM
Sal Collaziano's Avatar
Sal Collaziano
Default Changing my own starter...
Hey. If I were to change my own starter - is there anything I need to know beforehand? Can I drive up onto ramps or is my '87 too low?
Thanks in advance...
Old May 28, 2003 | 08:54 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Changing my own starter... (Sal Collaziano)
It is too low unless your ramps are really long.
If you just have ramps, it is too low.
Old May 28, 2003 | 09:06 PM
Vic'89's Avatar
Vic'89
Default Re: Changing my own starter... (bill mcdonald)
I think ramps should be ok. It would be good to have a floor jack also, in case you need to raise it higher.
Dropping the Ypipe should make it easier.
Vic
Old May 28, 2003 | 09:15 PM
bill mcdonald
Default Re: Changing my own starter... (Vic'89)
Right, ramps will be high enough, but dont drive up them.
Old May 28, 2003 | 10:06 PM
CFI-EFI's Avatar
CFI-EFI
I drive up my Rhino ramps. They have no provision for extra low cars, but my stock height '84, with full spoiler, only scrapes lightly, starting up them.
After the car is in the air, or before, if you're not driving it up ramps...step one, is to disconnect the battery. All the rest will be intuitive. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old May 28, 2003 | 10:39 PM
DESPERADO's Avatar
DESPERADO
Default Re: Changing my own starter... (CFI-EFI)
I just changed mine last week (87). What a PITA! The manual transmission oil lines are in the way, as well the exhaust does not leave much room.
I did it without removing anything extra, but it was an art of twisting and winding the starter to drop it through a hole to the right, between the exhaust and the body.
I understand there should be a bracket holding the tranny lines in place, if you remove the bracket you should be able to more the lines out of the way.
I put mine on an axle stand under the engine crossmember.
[Modified by DESPERADO, 8:40 PM 5/28/2003]
Old May 28, 2003 | 11:20 PM
Frizlefrak's Avatar
Frizlefrak
Sal....if you buy the plastic extensions for the ramps, you can drive up on them without scraping the front end. Since the tires are so wide, I have an assistant guide me up just in case. You can change the starter on the ramps. I wouldn't call it fun, but it isn't overly difficult.
Old May 29, 2003 | 03:54 AM
BIG JIM 54's Avatar
BIG JIM 54
It's a pretty simple project. No need to drop the exhaust. Be sure and disconnect the battery first. Oh and watch out with the ratchet. I slipped and broke the Knock Sensor on my '87.
BIG JIM
Old May 29, 2003 | 09:46 AM
OleDog's Avatar
OleDog
Default Re: Changing my own starter... (BIG JIM 54)
You can probably make any kind of ramps work with a couple of pieces of 2x6 on each side to drive onto the ramps.
While you're under there, if you haven't changed the fuel filter now might be a good time.
Old May 29, 2003 | 06:14 PM
Ramjet's Avatar
Ramjet
Changed my starter last week, used floor jack and some jack stands. Had plenty of room on my '92 LT-1 w/auto.
:seeya
To Changing my own starter...
