HOTCAM
Old May 29, 2003 | 01:03 AM
Epyon127's Avatar
Epyon127
Default HOTCAM
I like the specs and archive results for people using the HOTCAM. But I would rather have Pro-Magnum Rockers, 7/16" studs, double springs, etc...
than the kit stuff. Am I being stupid and or does anyone sell just the cam?
PS does the hotcam work with the GM Extreme Duty timing chain and stock everything else?
Old May 29, 2003 | 01:10 AM
Zix's Avatar
Zix
Default Re: HOTCAM (Epyon127)
You do not have to buy the Hot Cam Kit, you can just buy the cam and use whatever rockers/valve springs/push rods you want. The GM part # for jsut the cam is 24502586, it's $166 from http://www.GMPartsDirect.com
And yes, you can user the GM Heavy Duty timing chain with it
[Modified by Zix, 12:11 AM 5/29/2003]
Old May 29, 2003 | 11:12 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: HOTCAM (Zix)
However, to use the GM Extreme Duty chain, you must upgrade your timing cover and optispark, as it wont fit under the '92-'94 covers, and the older style opti, wont fit with the new covers. And I would HIGHLY recommend upgrading from the stock chain.. its definately good insurance.
-Mark
Old May 29, 2003 | 11:26 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: HOTCAM (MarkLT1)
I'm using a new stock chain with my set-up. I won't be cranking the rpm's you guys are but if something happens regarding the chain, I'll be sure to post it in this section. :thumbs:
Old May 29, 2003 | 07:24 PM
NickC493's Avatar
NickC493
Does anyone make a timing chain other than the GM extreme duty that will work with the hot cam kit, so that the pre 95 guys don't have to go through all that trouble???? :confused:
Old May 29, 2003 | 07:39 PM
Zix's Avatar
Zix
Default Re: HOTCAM (NickC493)
Check with http://www.cloyes.com they make the GM HD unit and make very high quaility components.
Old May 30, 2003 | 01:10 PM
sothpaw2's Avatar
sothpaw2
I figured I would change my opti/waterpump out since they were original,
10 yr old car, 76 kmi.
To HOTCAM
