95 Corvette ABS question.
Old May 29, 2003 | 09:13 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default 95 Corvette ABS question.
Would a ABS Brain & Pump assembly from a 96 Automatic Transmission Vette work on a 95 Vert with 6-speed???
Does anyone know?
[Modified by GrandSportC3, 9:14 PM 5/29/2003]
Old May 30, 2003 | 06:06 AM
Atok's Avatar
Atok
Default Re: 95 Corvette ABS question. (GrandSportC3)
I don't know but probably. I would go to your local GM dealer and look up the part number for this unit on each car. See if the part numbers match.
Old May 30, 2003 | 08:55 AM
GrandSportC3
Default Re: 95 Corvette ABS question. (Atok)
Thanks!!! I will check..
Old May 30, 2003 | 09:28 AM
GrandSportC3
The Modulator Valve (pump) is the same.. but the control unit has a different part number...
Old May 30, 2003 | 11:23 AM
Skippy Stone's Avatar
Skippy Stone
Hmm, I've been thinking about using a GrandSport controller in my 90. Ever since putting 11" on the rear, I get premature ABS pulsing in corners. I wonder if this would fix it.
To 95 Corvette ABS question.
