Anyone seen this(service engine soon question)
Old May 30, 2003 | 01:00 AM
C4Fanatic's Avatar
C4Fanatic
Default Anyone seen this(service engine soon question)
I pulled out to pass a truck tonight and when the revs got to the shift point the "service engine soon" light came on. I let off the throttle, engine came back down to cruise revs and it went out. Run it up and down a couple more times and same thing. I have noticed a little engine ping at the shift point rpm lately. Any ideas??? :confused:
Old May 30, 2003 | 01:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Anyone seen this(service engine soon question) (C4Fanatic)
Put a paper clip ends into ALDL pins A & B (upper right), turn the ignition on, count the SES light flashes (first a "12" is flashed twice, then each trouble code is flashed twice, followed by a "12" twice to signify the end of the codes).
Come back with the codes.
Old May 30, 2003 | 01:09 AM
C4Fanatic's Avatar
C4Fanatic
Default Re: Anyone seen this(service engine soon question) (65Z01)
I'll try that tomorrow, thanks. :thumbs:
Old May 30, 2003 | 06:56 PM
sailrmon's Avatar
sailrmon
Turn the ignition on but NOT the engine! :nono:
Old May 30, 2003 | 07:17 PM
MrNuke's Avatar
MrNuke
Check your EGR valve or switch.. Sounds like the culprit..
Old Jun 1, 2003 | 02:06 AM
C4Fanatic's Avatar
C4Fanatic
Code 21 throttle position switch too high. Found a buddy with a code checker. Think that the tps is set wrong? Looked it up in the Haynes manual and it gave the correct voltage the tps should put out with the throttle body in the idle position. Probably get a chance to check it out this week. The SES light seems to have went away. That was the only code I had, knock on wood.
Old Jun 1, 2003 | 02:12 AM
65Z01's Avatar
65Z01
Good job, that should be easy to correct.
Remember that .54Vdc is to be set at base idle of 450rpm not operational idle or 700rpm of so.
Old Jun 1, 2003 | 11:20 PM
C4Fanatic's Avatar
C4Fanatic
Thanks for the help James. :thumbs:
To Anyone seen this(service engine soon question)
