UHOH... Code 36 - MAF Burnoff Module on an '85 vette..
I might have an issue..
<NOTE> I don't notice any issues wiht the car. No rought running, no stalling, nothing bad really.
I hooked up my Actron Scantool to my '85 vette to show how to use it to a friend who's borrowing it, and I noticed it said it had an error code. I read it, and it said CODE 36- Mass air Flow Relay problem..
I am not getting a check engine light though and don't seem to have any issues with the car. I will clear the ecm memory now and check for codes again, but I thought when there is a problem with the MAF or burnoff module/relay you get a Check engine light and or problems with idle and stalling?
And yes my Check engine light is working normally..
Re: UHOH... Code 36 - MAF Burnoff Module on an '85 vette.. (hngacurv)
That's what I'm thinking... On mine it is an expensive issue to change the burn-off module as it is an '85 only setup. It doesn't use 2 seperate relays as the '165 ecm. I would have to switch to a newer ECM if that were the case. I don't have a spare '85 module on hand ..
