1.7 Roller Rockers..
Old May 31, 2003 | 12:25 AM
djbraxton's Avatar
djbraxton
Default 1.7 Roller Rockers..
Need some help locating some information on installing these rockers. I have read the post, but now I can not find it. Can I get alittle help on locating the info....
Thanks alot,
Old May 31, 2003 | 12:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1.7 Roller Rockers.. (djbraxton)
Someone will no doubt come along with that thread.
For sure you will need to change push rod length; so an adjustable pushrod will be needed to determine proper length.
What RRs did you get; full roller?
Wow, that's going to give you a nice effective cam!
[Modified by 65Z01, 12:42 AM 5/31/2003]
Old May 31, 2003 | 12:53 AM
djbraxton's Avatar
djbraxton
Default Re: 1.7 Roller Rockers.. (65Z01)
Thanks for the reply 65Z01, I have the Hotcam with GM 1.6RR and would like to give the cam alittle more lift. From what I remember reading is that the 1.7's increased the torque across the rpm band....
DJ
Old May 31, 2003 | 01:15 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
If your heads are modified to utilize the additional lift and the springs can accomodate it, then you may see similar results. You can do a search for Nathan Plemons and you should find it. I am pretty sure it was here in the C4 Tech section.
Old May 31, 2003 | 01:17 AM
65Z01's Avatar
65Z01
Well they will give you 6% more lift and 2deg more duration over the 1.6RRs.
Usually more duration tends to cost a little low end torque (more overlap) unless CR is increased to offset it. But I don't think you will notice the 2% down low though you might see the top end gain on a time slip.
To 1.7 Roller Rockers..
