Calling all rear gear experts!
Old May 31, 2003 | 09:22 AM
Dark-Knight's Avatar
Dark-Knight
Default Calling all rear gear experts!
I have a Z07 wiht 307 gears. Would like to change gears, possibly to 373's but undersatnd the pumpkin won't accomadate the gears. Does that mean I would have to swap our the entire axel? I am concerned what that may do to suspension attachement points.
Can you give me an idea what needs to be done and how much somthing like that might cost!
Thanks! :seeya
Old May 31, 2003 | 11:01 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Calling all rear gear experts! (Beautiful Beast)
I am by no means an expert, but you CAN buy 3.73s for your Dana 36.
you should have no problems.
Old May 31, 2003 | 11:34 AM
vader86's Avatar
vader86
You have a Dana 36 carrier in the automatic, there are 3.73 gears available for your carrier.
The bigger D44 carrier is stronger and has more gear options, it wont mess up the suspension points because its the carrier used in the manual vettes, You should put in the D44 if you like to drag race alot.
Old Jun 1, 2003 | 09:21 AM
Dark-Knight
Default Re: Calling all rear gear experts! (vader86)
Vader!
Did not know 3.73's were available for the Dana 36. In your opinion, what are the upsides and downsides of making the change from 3.07 to 3.73's?
Many thanks!
Old Jun 1, 2003 | 03:03 PM
CFI-EFI's Avatar
CFI-EFI
My listings don't show a 3.73 available from Dana for the 36. Likely there are aftermarket gears made for the 36. I believe I have seen 3.75's. Just be sure to get a "normal" thin gear. There are special "thick" gears, sold to install 3 series gears on a 2 series case. In your instance, installing 3 series gears on a 3 series case, requires nothing special. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
To Calling all rear gear experts!
