ALDL serial wire
Old May 31, 2003 | 07:09 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default ALDL serial wire
Mine has intermittent continuity to the chassis ground only when the ECM is hooked up. Is this normal?
Old May 31, 2003 | 09:16 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: ALDL serial wire (CarAteMyMoney)
Assuming the drive transistors to that line are standard RS-232 type, the impedence may be very high without power.
Old May 31, 2003 | 10:16 PM
CarAteMyMoney
Default Re: ALDL serial wire (65Z01)
i get intermittent continuity between the serial wire, and the pin on the ECM harness when the ECM is connected and on. when i unplug it, no more continuity
i tried your field service mode thing, and it seems like my car is running OK even though i get wacky numbers on the scanner. when i rev the gas, it goes from wacky numbers to no connection at all.. i dont get it
To ALDL serial wire
