Stopping distance for stock C4
Old Jun 1, 2003 | 10:04 PM
RMK's Avatar
RMK
Default Stopping distance for stock C4
Just wondering what the stoppping distances are for the C4 for both the standard 12" brakes and the optional/ZR1 13" brakes.
Robert
[Modified by RMK, 3:04 AM 6/2/2003]
Old Jun 1, 2003 | 10:19 PM
scorp508's Avatar
scorp508
Default Re: Stopping distance for stock C4 (RMK)
Well a 1987 Road & Track I have says my '87 should do...
60-0 : 131 feet
80-0 : 230 feet
Take it for whats its worth, its a magazine. Tires are much better now and I have miserable 11.5" rotors.
Old Jun 1, 2003 | 11:26 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Stopping distance for stock C4 (scorp508)
I never physically measured, but I can make the first turnoff at Raceway Park, not an easy feat at 108-110 mph!
Most cars need to go to the second turnoff at the very least. I usually use the 2nd or 3rd to save the brakes, but as part of a test I was conducting, I tried the first turnoff and no problems.
I wish I could tell you the distances.
Old Jun 2, 2003 | 12:00 AM
BAM92's Avatar
BAM92
Reading a Motor trend mag here from 90. Should be similar results for a 87. 3300lb 6sd coupe with 13" brakes 30-0 28ft, 60-0 112ft, 3284lb auto coupe with 12" brakes 30-0 29ft, 60-0 109ft. zr1 for that year did it 27ft and 109 ft weighing 3481.
Old Jun 2, 2003 | 09:05 AM
Skippy Stone's Avatar
Skippy Stone
Default Re: Stopping distance for stock C4 (BAM92)
Wow: The ZR1 only took 4 ft longer than the shortest I've seen for a Z06. The weight alone would account for that difference. Maybe the C5 brake set-up isn't that much better than a J55 after all. :confused:
Old Jun 2, 2003 | 10:06 AM
ELEVENS's Avatar
ELEVENS
Default Re: Stopping distance for stock C4 (Skippy Stone)
Sure, the J55 C4's stop great the FIRST time. I'd like to see the numbers on successive attempts after the dreaded C4 brake fade comes into play. :eek:
Old Jun 2, 2003 | 02:04 PM
RMK's Avatar
RMK
Is the brake fade bad?
I'm thinking of retro fitting the 12" setup to the front of my IROC-Z. The 10.5" 1 piston items are, in a word, crap. There is also a lot of fade with them.
I'm thinking that the 12" C4 setup would be a good upgrade that will still allow me to keep the stock 16" wheels. The C5 setup seems to just hit the caliper, and I don't want to spend all that money and have them not fitting or have to grind down the caliper.
Also, was there a 1 piston caliper on early C4s?
Robert
To Stopping distance for stock C4
